Activity Forums Blackmagic Design ATEM 1 M/E vs. AV-HS400A
  • ATEM 1 M/E vs. AV-HS400A
    Posted by Will Murray on November 20, 2011 at 11:00 pm
    Hi Guys,
    Looking for a little input…. Currently running a Panasonic HS400A with 4 HD-SDI + 2 DVI sources. I had a chance to investigate the new ATEM switcher and broadcast panel over the weekend and wonder what I’d potentially be losing by moving to the ATEM? I noticed right away that the ATEM doesn’t have built in tally or PTZ control, but interested in seeing what else might be missing. I also hope the H.264 output from the ATEM TV Studio makes it in to the 1 M/E eventually.
    Will
    Hampus Lager replied 14 years, 10 months ago 3 Members · 2 Replies
  • Silvio Guedes
    November 21, 2011 at 11:49 pm
    Comprei recentemente o Atem 1 e sinto falta de 2 itens que para mim é muito importante.
    Primeiro. Possibilidade de usar clips de videos mais longos com formatos populares como, wmv, avi, mpeg e etc…
    Segundo. Possibilidade de gravar um formato mpeg4 apartir de seua saida usb 3.0.
    Fora isto, para mim está muito bom.
  • Hampus Lager
    November 22, 2011 at 2:59 pm
    You can get tally with the latest firmware and a ATEM camera converter via SDI, but I don’t have enough knowledge about tally yet to say more.
    You can’t reassign buttons yet. Button 1 is linked to input 1 (HDMI or component), buttons 2-4 to input 2-4 (HDMI) and buttons 5-8 to input 5-8 (SDI). I heard rumours about them working to fix this as a firmware update.
