Activity Forums Blackmagic Design ATEM 1 M/E question
  • ATEM 1 M/E question
    Posted by Charles Caillouet on March 14, 2012 at 1:24 am
    I have a 1 M/E switcher loaded with the 3.0 Mac software and firmware update.
    Everything seems to work as expected in this rev, with the exception of cuts in the A/B Direct mode.
    While Auto transitions keep the same source on each bus and change the color of the active source button, Cut transitions still toggle the busses. It is very confusing for operators to have Cuts and Auto transitions behave differently.
    Is there a plan to fix this or should i stay with PGM/PVW switching?
    C. R. Caillouet
    Vision Unlimited/LA
    HD Production Technical Support since 1987
    …searching for the right tool for the job…
    Charles Caillouet replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
