Activity › Forums › Apple Final Cut Pro Legacy › At wits end! Export Quicktime yields nonsync audio.
Posted by Tangier Clarke on November 27, 2009 at 3:40 amFolks, I can’t figure out what is causing this. The audio mix i have for my edit is in sync just fine in Final Cut (latest version) during playback. When I export a Quicktime movie using current settings, the audio is out of sync.
Details:
XDCAM EX 1080p24 sequence
Final Cut StudioSnow Leopard
Andy Mees replied 16 years, 9 months ago 4 Members · 9 Replies -
Andy Mees
November 27, 2009 at 4:11 amHow are you monitoring in FCP, what are your audio and video output paths?
How are you monitoring your exported quicktime movie? -
Tangier Clarke
November 27, 2009 at 4:44 amFrom FCP I am monitoring using desktop cinema preview and default built in audio
From Quicktime.app I monitor (the exported quicktime) using the same screen and default built-in audio. Nothing fancy here. I did check how I was monitoring everything – making sure I wasn’t sending audio to my Blackmagic Multibridge Pro.
Tangier
Tangier Clarke
November 27, 2009 at 7:11 pmHmmm. I hadn’t thought of that. I’ll use compressor and convert all my audio mixes to AIFF to place in my sequence. I was given all wav files.
Tangier
Tangier
Tangier Clarke
November 27, 2009 at 7:40 pmThat’s just it. The audio (as wav files) is perfectly in sync when I play it back in FCP. It is only after the export that it’s out of sync. This is terribly frustrating. Being that it’s in sync in FCP I wonder if changing the audio files to AIFFs will make any difference.
Tangier
David Roth weiss
November 27, 2009 at 9:00 pm[Tangier Clarke] “Being that it’s in sync in FCP I wonder if changing the audio files to AIFFs will make any difference. “
In less time than it took to write your post you could have converted one or all WAVs to AIFF. Why not try it and then report back. There’s no destructive part of the process to worry about.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Tangier Clarke
November 28, 2009 at 12:54 amOther than the wav vs. aiff issue, I’ve checked all of the settings and they match. The wavs were 48k. We’ll see how it goes.
Tangier
Tangier Clarke
November 29, 2009 at 7:50 pmI’ve gone through all of the checks and balances (equalizing settings) really even before I posted. The only succesful solution for me was to render all twelve episodes as quicktimes with their audio mix, reimport them and line them up on one timeline and export that as one massive quicktime.
This is the only way everything stayed in sync. Just nesting each episode and placing those nested versions back to back on a timeline only stay in sync during playback in FCP, not on a Quicktime export.
Wish it weren’t this way, but it’s the only solution that worked and allowed my to create a perfect Blu-Ray with sync audio.
Tangier
Chris Wyatt
November 30, 2009 at 11:44 amHi Tangier
are the .WAV files you received in BWAV format?
If they are you can get sync drift as FCP or QuickTime unsuccessfully tries to chase the embedded timestamp sample information.
Heres a few recent COW links to look at:
https://forums.creativecow.net/thread/8/1031111
https://forums.creativecow.net/thread/8/1022132#1022140Best Regards
Chris Wyatt -
Andy Mees
November 30, 2009 at 11:47 amthis recent blog post by Oliver Peters touches on a possibly associated issue, and he notes a workaround which may be something you can also try:
https://digitalfilms.wordpress.com/2009/11/29/11-more-final-cut-pro-tips/look to item number 5) Audio files running at the right speed
