Activity Forums Compression Techniques At my wit’s end….. Need info on using ffmpeg to convert mp3 and image to mp4
  • At my wit’s end….. Need info on using ffmpeg to convert mp3 and image to mp4
    Posted by James Robinson on October 5, 2019 at 1:16 am
    Hello all.
    I have combed the internet, tried everything suggested, and am in dire need of help.
    I am trying to add a jpg file to an mp3 and convert it to an mp4 to put on a DVD.
    I am using multiple files (both mp3 and jpg) in a directory, as follows:
    MP3 files: (48 kbps, 24000 Hz, Mono)
    nwt_60_1Pe_E_01.mp3
    nwt_60_1Pe_E_02.mp3
    nwt_60_1Pe_E_03.mp3
    etc, etc.
    JPG files from mp3 tag: (600×600, 600 dpi)
    etc., etc
    My goal is : (Video: 600×600, Data rate: 47 kbps, Total Bitrte: 157 kbps, FPS: 25; Audio 110 kbps, 24,000 Hz, Mono)
    nwt_60_1Pe_E_01.mp4
    nwt_60_1Pe_E_02.mp4
    nwt_60_1Pe_E_03.mp4
    etc, etc.
    I need the command line to count the total # of MP3’s and convert them automatically.
    Thank you all very much in advance for your help.
    James Robinson
    James Robinson replied 6 years, 11 months ago 2 Members · 2 Replies
  • Lou Logan
    October 9, 2019 at 6:49 pm
    ffmpeg can’t do this by itself. You need to use additional features present in your shell/command line.
    The answer depends on what you are using, but you didn’t mention your OS.
    For Linux or macOS you can use a Bash for loop:
    for f in *.jpg; do ffmpeg -framerate 25 -loop 1 -i "$f" -i "${f%.*}.mp3" -c:v libx264 -vf format=yuv420p -c:a aac -movflags +faststart -shortest "${f%.*}.mp4"; done
    If you’re on Windows refer to cmd, batch file, or PowerShell help resources regarding a “for loop” or whatever the Windows equivalent is.
  • James Robinson
    October 9, 2019 at 7:09 pm
    Lou,
    Thank you for your response. I am using Windows 7.
    I will give it my best shot, but may be back….
    Thank you again,
    James
