Activity Forums Adobe After Effects Asus n56vz laptop for After Effects?
  • Asus n56vz laptop for After Effects?
    Posted by Engin Osmanovski on December 31, 2012 at 2:14 pm
    Is this Asus N56VZ laptop a good option to work with After Effects thoroughly? (Also C4d and 3ds max…). I am giving some key specs below:
    – İ7-3630QM 2.4 GHz (Up to 3.4 GHz with Turbo Boost)
    – 16 GB RAM
    – NVIDIA GeForce GT 650M 128Bit (4GB)
    – 1TB Hdd (5400 rpm)
    Engin Osmanovski replied 13 years, 5 months ago 3 Members · 5 Replies
  • Todd Kopriva
    December 31, 2012 at 6:07 pm
    That’s a very slow hard disk drive, and that will slow down your work. It doesn’t meet the minimum system requirements.
    See this page for information about hardware for After Effects: https://adobe.ly/pRYOuk
    After Effects team blog
  • Engin Osmanovski
    December 31, 2012 at 9:43 pm
    What if i replace the hdd with a 7200rpm one? Still bad?
  • Todd Kopriva
    December 31, 2012 at 9:59 pm
    That does at least meet the minimum system requirements. Follow the link that I gave to learn all about what hardware factors influence performance and how.
  • Suniel Kummar
    March 27, 2013 at 11:23 pm
    Hi there,
    Any idea why wont above configuration work even after changing the hard disk to 7200 RPM? Sorry I tried looking at the link above but can’t find the reason, any help is much appreciated.
    Cheers,
  • Engin Osmanovski
    March 28, 2013 at 3:57 pm
    If i am not wrong, it will work with a 7200. Just won’t work efficient/fast enough with only 1 disk. They recommend “at least” 2 (1ssd + 1hdd) internal disks for AE. (More is better). It is a matter of separating the read and write process. The more you distribute these tasks to different disks, the more performance you get.
