Activity › Forums › Adobe After Effects Expressions › Asteroids-like “Screen Wrap” effect?
  • Asteroids-like “Screen Wrap” effect?
    Posted by Phil Aupperle on April 18, 2016 at 10:35 pm
    I have the “throw” expression on the x position parameter of a layer, and I’m trying to modify it to return to 0 after it goes past a certain point, like the asteroids in Asteroids. AE is fine with this code, but the layer just keeps going off to the right, never to be seen again. What am I missing? Is the value of x not being updated with the current position on every frame, is it not getting reset to 0, or is there a problem with using only one of the values from position?
    Thanks in advance…
    veloc = 300; //horizontal velocity (pixels per second)
    x = position[0];
    if (x > 500) {
    x = 0;
    } else {
    x = position[0] + (time - inPoint) *veloc;
    x
    Kalleheikki Kannisto replied 10 years, 5 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    April 19, 2016 at 2:26 pm
    If you separate dimensions, you can use “x” value only.
    This would be one way to do what you are describing (use for x-position after separating dimensions):
    x = (value+ (time - inPoint) *veloc) % 500
    It works in the positive direction only.
