Associating Files
Posted by Roger Bansemer on October 20, 2010 at 5:01 pmBy associating the Vegas 10 files by using this message below, will that prevent me from opening the project in Vegas 9?
Roger Bansemer replied 15 years, 10 months ago 4 Members · 4 Replies -
Mike Kujbida
October 20, 2010 at 5:22 pmRoger, that only means that if you double-click on a veg file in a folder, the project will open in Pro 10 as opposed to whatever version was used to create it.
It shouldn’t stop you from opening it in the original version either.After installing a new version, it’s always a good idea to rename old projects to reflect the version that they were created in so that you don’t accidentally save over them with a newer version, thereby preventing you from opening it with the older version.
Stephen Mann
October 20, 2010 at 5:27 pmNo. It just means that when you double-click on a veg file, Windows starts Vegas Pro 10 and open the veg project.
If you need to open a Version 9 project, just double click on the Pro 9 icon – not the veg file, then drag the veg file to the blank project.
You should probably back up your V9 veg files because when you save a project from V10, you can’t open it again in V9.
FWIW – I installed V10 in mid project, I have that much confidence in my PC and in Sony Vegas, and I am quite pleased with the performance and feature improvements.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Tom Edwards
October 20, 2010 at 5:52 pmassuming you’re using a windows machine, you can also right click on the file, select ‘open with,’ then select 9.
