Activity Forums Adobe After Effects Assistance to visually reverse engineer a clip and share as to how you think it was done.. :)
  • Assistance to visually reverse engineer a clip and share as to how you think it was done.. :)
    Posted by Thomas Brigantino on October 17, 2016 at 11:00 pm
    To keep this short, I attached a 35 second clip of a style of video tutorial presentation that I want to create. If you can please provide your expert assessment as to all things necessary to create with consideration of what I think below, that would be very much appreciated!
    10690_timelinepm2vtproprojectiontypes.webm.zip
    Assessment:
    Background, when visible as the display torque left or right and it seems to behave with a Wiggle Expression.
    Computer Display, I think it is a 2D object, flat and pre-composed containing the video layer.
    Camera Rig, attached to a Null Object, the Camera Settings are a bit elusive with a narrow focal point, there are several preset camera movements used repeatedly and I feel that behavior is driven by expressions rather than keyframe.
    Looking for your guidance, thoughts on what you assess and if there is a plugin that can create this sharing what it is would be great!
    Thank you!
    Thomas
    Jim Arco replied 9 years, 11 months ago 2 Members · 1 Reply
  • Jim Arco
    October 19, 2016 at 12:04 pm
    I suspect you’re not getting any responses because your link is to a zip file. Most folks don’t like to have to down load a file, and many are concerned about viruses. Then your zip contains a .web file which doesn’t play on my PC.
    Can you provide a different format?
    Jim
