Activity Forums Adobe Encore DVD Assigning in and out points to buttons
  • Assigning in and out points to buttons
    Posted by Chet Wesley on July 21, 2008 at 6:35 pm
    I am new to Encore, I have a question.
    I am trying to set up a DVD which has clips that are all pulled from one longer media file.
    The idea is to have a menu with buttons which navigate to a certain clip. The clip is supposed to play, and then when it reaches the end marker, return to the menu.
    The clips I would like to use have been marked off with markers in the main sequence. I have marked points for both in and out of each clip in the sequence (when the clips should start and when they should end).
    However, I need to have a separate button which plays a longer segment all the way through without stopping at those markers within it.
    I have set up a menu with buttons which navigate to the appropriate place to start (which works fine), but I can’t see a way to tell it that it is only going to play up to a certain point and then go back to the menu.
    Is there a way to assign a button so that it is pointing to both an in and out marker?
    Am I setting this up or thinking about this in the wrong way?
    Simon Bonner replied 18 years, 2 months ago 2 Members · 1 Reply
  • Simon Bonner
    July 22, 2008 at 12:24 am
    Have you thought about setting it up with a series of playlists? Someone else pointed that out to me as a possibility when I had a similar project issue to the one you’re describing. Search in your helpfiles for playlist and see if you can do anything with it.
    Simon Bonner
    youtube.com/simonsaysFX
