Activity › Forums › Maxon Cinema 4D › assigning Different colors to each sweep stroke
Jim Scott replied 8 years, 2 months ago 5 Members · 14 Replies
Jim Scott
July 24, 2018 at 2:29 am[Steve Bentley] “I haven’t tried this but once you get the traces from the particles can’t you feed those into the sweep object to be the path? Or, because it’s one emitter for the particles, does the sweep see the traces as one giant path made of all the traces?”
Yes, that works fine, and it does create separate sweeps for each particle. The question is, how do you control those paths to create an image similar to what Ranveer provided?
Emir Bojorquez
July 24, 2018 at 4:00 amIs this what you are looking for?
12571_colorssweepexample.c4d.zip
With the noise Low and High Clip of the first material, you can move through the colors of the second material.
Good Luck
Emir
pixldgblog.comImagination is the best tool…
Ranveer Singh
July 24, 2018 at 5:01 amThank you for helping me out here. This is 90% it what I wanted. just a bunch of line going diagonally.
this is what I came up with. It is still not perfect though but more simple. https://drive.google.com/open?id=1S-vesP7UvlUpb9HCt6VuuKqK5lzR3tyJ
I want the sphere with lines in the image to rotate. -
Jim Scott
July 24, 2018 at 1:06 pm[Ranveer Singh] “I want the sphere with lines in the image to rotate.”
Looks good Ranveer. Now just rotate the cloner.
