Activity › Forums › Apple Final Cut Pro Legacy › Assembly Editor
Assembly Editor
Posted by Karen Gall on November 24, 2009 at 12:47 amWhat is the definition for an assembly editor & what exactly does that entail?
Karen Gall replied 16 years, 9 months ago 4 Members · 5 Replies -
Shane Ross
November 24, 2009 at 1:01 amTHis is typically for a feature film. This is someone who just takes the shots and puts them on order on the timeline…so like ALL the shots from scenes, after ACTION is called, so that you can see all the performances…see all the footage instead of seeing things like ROLL CAMERA, SLATE, MARKER, ACTION, then the shots.
I think. Because that is what AN ASSEMBLY is. Or typically the ASSEMBLY EDIT is the editors original first very rough cut of the show. Just a very rough layout of all the shots you feel are the best. That you later go back and redit tighter for emotion.
Might also mean OFFLINE editor…basically the creative cutter on a show, not the finishing editor, or ONLINE editor.
Shane
Read my blog, Little Frog in High Def -
Karen Gall
November 24, 2009 at 1:06 amHey tks for the quick response Shane…that’s what my understanding is. Just wanted to double check as this will be my first official feature!
John Knapich
November 24, 2009 at 1:47 amOr..an editor who works at our company. teehee
FCP 6.06, OS 10.5.8 2x3GHZ Quad-Core Intel Xeon, Kona LHe, Dulce Duo-eSATA 8 Drive, 4TB Raid.
John Knapich
Creative Director/Partner
Assembypix.tv -
Aaron Neitz
November 24, 2009 at 3:28 amwhen we ask for an Assembly, it means taking all the circle takes and slapping together a rough scene.
Otherwise, just like Shane says: cut out all the junk and put it together in rough order.
