Activity › Forums › Adobe Encore DVD › Assembling spots from separate files.
Posted by Bill Oneil on August 21, 2005 at 1:08 amI
Bill Oneil replied 21 years ago 3 Members · 8 Replies -
David Garrett
August 21, 2005 at 5:24 pmyou can link all the spots timelines to each other by using the “end action” of each seperate timeline, or if you are using Encore 1.5 you can use the “playlist” function to make the job easier for you.
as for the audio, encore will automatically encode it to the best quality that it thinks will be best to fit on the DVD
you can find loads of Encore tuts on my site http://www.sitesled.com/members/doogs/
Bill Oneil
August 22, 2005 at 12:41 amThanks, Dave. The playlist feature was the perfect solution and just what I was looking for. However, I was unable to get a preview working. I think that’s because I had around 30 spots chained together and the program has to get them in cue. But the DVD I burned worked fine.
I think Adobe could improve this feature by allowing the user to sort the timelines in the playlist alphabetically and otherwise. It would also be nice to have the ability to select all the timelines and do a global import to the playlist instead of this “one at a time” stuff.
I enjoyed your tutorials as well.
Bill O’Neil
http://www.chicagospots.com -
David Garrett
August 22, 2005 at 1:45 amglad to be of help Bill, will have to check out your tuts for AE… i am really missing out on the power of that application
Joe Bowden
August 22, 2005 at 2:25 pmI think Adobe could improve this feature by allowing the user to sort the timelines in the playlist alphabetically and otherwise. It would also be nice to have the ability to select all the timelines and do a global import to the playlist instead of this “one at a time” stuff.
Bill, try this: Sort your timelines in the Project window, then select them all and create a new playlist.
The new playlist should be fully populated and sorted as in the Project window.
Enjoy,
Joe -
David Garrett
August 22, 2005 at 6:01 pmgreat bit of info Joe…. would you mind if I made a little video tut on the technique you just described. Will give you full credit for the tip 😉
Joe Bowden
August 22, 2005 at 6:43 pmFeel free, David. And thanks for the tutorials you’ve posted- I can see from this forum that you’ve helped a lot of users.
Cheers,
Joe -
David Garrett
August 23, 2005 at 12:12 ammany thanks Joe for the most kind words and for allowing me to record your tip. it has been done and upped to my site now. Tut #14 in the intermediate section.
Bill Oneil
August 23, 2005 at 1:40 pmGreat tip, Joe! Thanks David for the tutorial. I will use the playlist feature a bunch!
Bill O’Neil
