Activity › Forums › Blackmagic Design › Assemble/Insert Export to tape 4 frames to late
Posted by Igor Babic on February 10, 2006 at 3:28 pmPPro2 Decklink Extreme PCI, Drivers 5.4.1 for Multibridge.
All was OK in PPro 1.5 and drivers 5.4. Capture is always frame acurate.
I am trying to export to PVW 2800 Betacam SP deck.
Preroll 5 sec. Delay Movie start 0 frames, Manual edit timing 0 frames.Igor Babic replied 20 years, 7 months ago 2 Members · 4 Replies -
Igor Babic
February 10, 2006 at 3:36 pmAssemble/Insert starts at in point that you enters but program is recorded 4 frames later. Those 4 frames are filed with still frame from timeline at witch pointer stands before you enter export to tape window in PPro20.
Shane Chadder
February 10, 2006 at 4:56 pmIgor
You now have to do some configuration to sync printing to tape up.
First – Manual edit controls the actual inpoint on the tape. We find 5 works on our machines so you might want to start there. You have to get this right first. Take a black tape, a timeline with bars, park your cursor on bars (so bars is in the frame buffer on screen), record and check the inpoint for accuracy.
Seond – Delay start controls when Premiere plays the timeline. Again I think 5 works for us. If this is off in one direction you record whatever is in the frame buffer for a few frames, if it is off in the other you miss the first few frames of your show. I suggest a timeline of single frame countdown to set this.
This fun is thanks to Adobe and not Black Magic.
Shane Chadder
February 10, 2006 at 5:01 pmIgor
Igor Babic
February 10, 2006 at 9:42 pmHmm…
I have done this: Put a cursor at black part of timeline, mark in point 4 frames earlier on tape in export to tape window, autoedit.
I have not noticed eating of first few frames, and as I recall that works perfect in PPro 1.5. I will doo some further testing at monday.
Thanks Shane, I will report you.
