Activity Forums Apple Final Cut Pro Legacy Aspect Ratios from DVD’s in FCP
  • Aspect Ratios from DVD’s in FCP
    Posted by Daniel Corcoran on June 18, 2008 at 3:06 pm
    Hi There,
    I am begining a project where I need to edit 15sec segments from about 10 different DVD’s- my question is:
    What is my best option to get the different DVD clips all in the the same aspect ratio- should I import them all in 4:3 or 16:9 from steamclip, or is there a way to make all the clips look like they’re in the same aspect ratio within FCP?? Ideally I want all the clips that I rip looking the same when I start to edit all the footage on the timeline??
    I am using Handbrake to rip the DVD’s into MPEG4 then using streamclip to make the files into DV after which I import directly into FCP??
    Also can I use streamclip to bypass Handbrake when ripping the DVD’s into DV??
    Thanks very much
    Daniel
    Rafael Amador replied 18 years, 3 months ago 2 Members · 1 Reply
  • Rafael Amador
    June 18, 2008 at 3:41 pm
    [Daniel Corcoran] ” am using Handbrake to rip the DVD’s into MPEG4 then using streamclip to make the files into DV after which I import directly into FCP?? “
    This makes no much sense. Why don’t you avoid to pass by MP4.
    Why don’t you go from the DVD drectly to a .mov that you can edit in FC?
    Rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
