Activity Forums Apple Final Cut Pro Legacy Aspect Ratios
  • Posted by Daniel Corcoran on June 18, 2008 at 3:18 pm
    Hi There,
    I am begining a project where I need to edit 15sec segments from about 10 different DVD’s- my question is:
    What is my best option to get the different DVD clips all in the the same aspect ratio- should I import them all in 4:3 or 16:9 from steamclip, or is there a way to make all the clips look like they’re in the same aspect ratio within FCP?? Ideally I want all the clips that I rip looking the same when I start to edit all the footage on the timeline??
    I am using Handbrake to rip the DVD’s into MPEG4 then using streamclip to make the files into DV after which I import directly into FCP??
    Also can I use streamclip to bypass Handbrake when ripping the DVD’s into DV??
    Thanks very much
    Daniel
    Eric Johnson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Eric Johnson
    June 18, 2008 at 5:04 pm
    I would suggest keeping everything at the aspect ratio it originates as (I’m assuming when you say 4:3 you mean 4:3 Letterboxed and not full screen, correct?) and cutting 4:3 in FCP. You don’t really want to be blowing up 4:3 to 16:9.
    Also, to keep everything looking like it came from the same source, more or less, nest your final sequence and put a widescreen filter with what ever aspect conceals your frame lines to keep it looking consistent.
