Activity › Forums › VEGAS Pro › Aspect Ratios
  • Aspect Ratios
    Posted by John Perez on January 13, 2018 at 5:06 pm
    I see films with 2.4 to one aspect ratio. What format are they using, what codecs?
    HP Intel(R) Core i-7 CPU
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
    As always thanks so much to you guys…Johnny In Orlando
    Francois Pénzes replied 8 years, 8 months ago 2 Members · 1 Reply
  • Francois Pénzes
    January 14, 2018 at 3:10 am
    Hi John
    I’m at a bit of a loss to understand why you would want to take this road. The 2.40 to 1 format (actually 2.39) was originally developed in order to make full usage of the frame on 4-perf film. It is shot with an anamorphic lens and when projected the process is reversed.
    Now, if you want that ”Panavision” look, change your parameters to 1.2121 (File/Properties/Video/Pixel Aspect Ratio)
    Don’t forget to shoot and frame accordingly.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
