Activity Forums Apple Final Cut Pro Legacy Aspect ration problem
  • Aspect ration problem
    Posted by Dylan Etherington on February 13, 2010 at 4:26 pm
    Afternoon all.
    I have a problem with my aspect ratio and letterboxing on FCP.
    On a camera with a 4:3 chip, I set it to record in 16:9. Now I know that this isn’t real 16:9 so when I came to digitise I ticked anamorphic and when I came to edit my first sequence everything was fine. I got a full frame 16:9 picture in the canvas with no letterboxing and all was hunky dory.
    Then I came to edit my second sequence in the same project and when I finished, I realised that the 16:9 image in the canvas was actually letterboxed in a 4:3 aspect ratio. When I tick anamorphic the image turns to a 16:9 letterboxed image so consequently it is squashed.
    How can get rid of the letterboxing to have everything in my timeline filling the 16:9 frame?
    Cheers,
    Dylan.
    Andy Mees replied 16 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    February 13, 2010 at 4:43 pm
    Dilan,
    Select all the clips and “Remove Attributes> Basic Motion”.
    Rafael
    http://www.nagavideo.com
  • Dylan Etherington
    February 13, 2010 at 4:52 pm
    Thank you but this isn’t working. ‘Basic Motion’ is greyed out…
  • Rafael Amador
    February 14, 2010 at 6:05 am
    Sorry.
    Remove attributes> Distort.
    rafael
  • Andy Mees
    February 14, 2010 at 9:28 am
    Just select all in your timeline and choose Modify menu > Conform to Sequence
    That should do it
    Andy
  • Rafael Amador
    February 14, 2010 at 9:54 am
    [Andy Mees] “Just select all in your timeline and choose Modify menu > Conform to Sequence “
    I’m still in FC5:-)
    This are the disadvantages of almost never working under pressure.
    I should go back to the edit boxes for awhile to get back the speed and the bad habits.
    Rafa
  • Andy Mees
    February 14, 2010 at 11:16 am
    Are you still running a PowerPC up there Rafa? If not then you’ve really gotta grab the 299 upgrade (to FCS 3) to go with all that fancy hardware you’ve already got.
  • Rafael Amador
    February 14, 2010 at 12:53 pm
    No, I’m working with an Intel and I’ve been with FC6 since the release but I’ve just upgraded to FC 7 (.0.1).
    But normally my editing is very slow . Often I write the script while I’m editing. Some times I write directly in the subtitles. I never work with an anxious boss or client looking from behind my shoulder.
    This is the only place in the world where you have to put the deadlines to the customers.
    Nothing that push me to edit faster. I’ve learnt plenty of short-cuts just to forget them for the lack of use.
    Anyway, If the mouse shows that is still alive, what can I complain about?
    You know that mouses have a hard life around here: Curry, satay, lap…, so many recipes.
    rafa
  • Andy Mees
    February 14, 2010 at 1:33 pm
    Mmmm, mouse. Yummy … goes really nicely with frog on a stick too 🙂
