Activity › Forums › Adobe Encore DVD › Aspect ration of this file is not supported by DVD error at 1.6016s
  • Syed Murs
    August 11, 2012 at 12:26 pm
    OK so I tried to follow your advice but before I could do that the Encore file in concern wouldn’t launch. It hangs up upon. Tried it several times even tried it after a reboot.
    Had to re-create the entire thing again on Encore and then transcoded it from start.
    When I went to press the Build button apparently I got a new problem where Encore wouldn’t recognize my DVD burner. Spent more time looking on the net for solutions. (solution to this new problem is that just create an ISO DVD image and once that is done use a program like ImgBurn to transfer it on to DVD disc).
    However, today when I woke up to check if the transcoding had finished I realized that now (somehow) I had the option of burning it directly on to the DVD disc and Encore was recognizing my DVD burner. Strange.
    Nonetheless, I did try out your remedy for the initial problem just to double-check and it is in fact in the Encore timeline you have to punch in the the erroneous time stamp (in my case 11671.8000s).
  • Huub Derksen
    April 8, 2025 at 1:32 pm
    Hallo Gretchen, years and years (15 years!) later you’re answer did help me.. I was also stuck on this issue… So, now i’m relieved and can finish my DVD-project
Page 2 of 2
