Activity Forums Adobe After Effects aspect ration is wrong please help!
  • Steve Roberts
    February 9, 2009 at 4:43 pm
    You should delete the clip from the FCP sequence then drag it back in.
    The switch needs to be clicked before the clip goes into the sequence, if I recall.
  • Alex Brazier
    February 11, 2009 at 4:11 pm
    have you tried to select the clip, and then adjust the distort in the motion tab of the viewer? sometimes this setting will affect your clip.
