Activity Forums Adobe After Effects Aspect ration from AE 5.5 to FCP 7
  • Aspect ration from AE 5.5 to FCP 7
    Posted by Joseph Colombatto on March 12, 2012 at 1:48 pm
    My sequence in FCP 7 is set @ 720×480 NTSC DV (3:2)
    Pixel Aspect Ratio: (NTSC-CCIR 601/DV NTSC 720×480) which looks fine on the timeline.
    I take a photograph and place it the timeline in a AE composition @:720×480 (locked Aspect to 3:2)
    Pixel Aspect @ D1/DV NTSC (0.91) and the picture looks fine in AE.
    I set scale and position key frames (for a slight pan and zoom), and it looks fine on a 10 second timeline.
    I then want to export as a .mov so I click Add to Render Queue and, then I set Output Module to
    Quicktime DV NTSC 48kHz and render.
    When I bring the finished AE mov back into FCP, it looks a little squished, as if the aspect ration is just off a little.
    What setting am I missing?
    Joseph Colombatto replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
