Activity Forums Adobe Premiere Pro Aspect Ratio/ Size changes for Program window
  • Aspect Ratio/ Size changes for Program window
    Posted by Bjorn Noren on June 16, 2015 at 11:50 pm
    I just started using the Adobe Premiere. Been using FCP but this came with the new (used) laptop
    I bought and I heard Premiere is better..
    The problem is that when I lay down footage to the timeline it displays in a different format on the Program monitor vs. the Source monitor (see Picture attached).
    It also displays in this different format when I export the sequence. It’s like its Zoomed in, I tried changing the size options on bottom of the Program monitor as well as changing from the Full – 1/2 options on bottom right of Program monitor but it won’t change!
    I have also tried making changes in Preferences without success… Please check out the picture and see if anyone can recognize what is wrong .?
    Thanks/ Bean
    Ivo Silva replied 11 years, 2 months ago 2 Members · 1 Reply
  • Ivo Silva
    June 19, 2015 at 11:25 am
    It seems to me that you created a sequence in the wrong format – different from the source.
    Drag a clip to the “new” button, down in the Project Panel, and see if the resulting sequence is in the right format.
