Aspect Ratio – Sequence and Capture not matching
Hi. Can anyone help me with this? I captured some footage in FCP 5 with the capture presets set to DVPAL anamorphic. This was the correct setting and the footage in the viewer looks fine. My sequence settings are also DVPAL anamorphic but when I look at my images from the timeline in the canvas they are distorted. The width is fine but the the height is crushed by about half an inch at both top and bottom. I can’t understand why there should be a problem when all the settings are matching.
Any help much appreciated.
