Activity Forums DVD Authoring ASPECT RATIO problems with DVD Studio Pro 3
  • ASPECT RATIO problems with DVD Studio Pro 3
    Posted by Carly_abyss on June 7, 2005 at 12:46 pm
    So… I have a 16×9 project that I have created in DVD Studio Pro 3. But for some reason when I put the disc in some DVD players, it centre cuts the menus. And then when you click on a button, the feature movie letterboxes. Why aren’t the menus recognised as 16×9 and also letterboxed when played on a 4×3 television?
    What am I not getting here?
    HELP !
    Kieran Matthew replied 21 years, 3 months ago 3 Members · 2 Replies
  • Chris Borjis
    June 7, 2005 at 8:07 pm
    what do you mean by “centre cuts the menu?”
    Did you design the menu’s with a 16×9 ratio
    before resizing them to 720×480 for authoring?
    Are there multiple video title sets in your project?
    This allows 4:3 and 16:9 on the same disc.
  • Kieran Matthew
    June 12, 2005 at 12:20 am
    There’s a check box in the general settings pane of the disc that says something like “if 16:9 is used…”. By default in DSP3 this is set to “Force to Pan & Scan” which zooms the centre section of your 16:9 menu. Set it to “force to letterbox” and it should solve the menu issue.
