Activity Forums Apple Final Cut Pro Legacy Aspect Ratio Problems with Clips
  • Aspect Ratio Problems with Clips
    Posted by Cephus on July 13, 2005 at 4:43 pm
    FCP is misinterpreting my footage. I’m running a 2.5 GHz G5 with Tiger and FCP 5. I’ve just noticed something interesting with my Clip Viewer. My project has clips in two different formats: 16×9 and standard. All my 16×9 footage is peachy, yet my standard 4:3 footage differs. Many of them load into the clip viewer as they should at full 4:3 ratio, but others load into the clip viewer as if they were anmorphic (with the grey area at the top and bottom of the viewer as it does with true anamorphic material). It will display properly on my NTSC monitor, but the viewer insists on squeezing it down. I’ve compared all of my logging info with my properly displayed 4:3 and there are no variations between the two. This happen to anyone else? From time to time my project viwer will act up as well. Sometimes it has a blue scanline overlay and sometimes it will be solid green, even though it will display properly on my NTSC monitor.
    FYI, The project is a feature in which, so far, I have over 800 clips. Many more to come. Is that too heavy for one FCP project?
    Behold My Electronic Signature
    Cephus replied 21 years, 1 month ago 2 Members · 2 Replies
  • Bryce Whiteside
    July 13, 2005 at 5:18 pm
    You probably need to read this post from two days age.
    Urgent Help needed with Aspect ratios! please!! by Alex on Jul 11, 2005 at 10:59:28 am
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Cephus
    July 13, 2005 at 6:43 pm
    Yeah, I had already read that before I posted. My problem seems to be the opposite. The viewer is taking a 4:3 clip and forcing it into an anamorphic format. I’m not talking about a black letterbox, I mean the viewer is interpreting it as anamorphic and squeezing it between the gray area of the viewer. The distortion settings are the same as any of the properly displayed 4:3 clips. In addition, they properly display on my NTSC monitor. I’m dumbfounded. But thank you for your suggestion on reading the previous post. Any others?
