Activity Forums Apple Final Cut Pro Legacy Aspect Ratio problems
  • Aspect Ratio problems
    Posted by Brad Buttner on October 2, 2011 at 9:12 am
    Hey guys
    After working on a recent five minute job in FCP6, I realized that I clicked on “no” when the “Warning – This clip does not match the sequence’s settings or any of you sequence presets” message (dumb, I know).
    So now I am sitting with an entire timeline full of clips appear slightly squashed.
    Is there any way to stretch the clip VERTICALLY? If I could do that slightly, then the aspect ratio of all my clips will be perfect and it would save me from redoing the project from scratch :/
    Thanks again and sorry if the problem is a trivial one 🙂
    Brad Buttner replied 14 years, 11 months ago 4 Members · 6 Replies
  • Rafael Amador
    October 2, 2011 at 4:50 pm
    Hi Brad,
    I guess is about fixing Attributes, but if you give a bit more of info on your footage and sequence settings, will be easier to try to find out the issue.
    rafael
    http://www.nagavideo.com
  • Brad Buttner
    October 2, 2011 at 7:38 pm
    Thanks for the reply Rafael
    I really think it is a simple issue relating to the sequence settings.
    Is there perhaps a way of just vertically stretch the clip, as it seems as though the footage is squashed.
    Thanks again
  • Eric Strand
    October 3, 2011 at 2:22 am
    What if you create a new sequence, drop a clip into it, click yes, then copy and paste your clips from the original timeline into the new one?
  • David Eaks
    October 3, 2011 at 2:46 am
    If you follow Eric Strands advice, it will work but the scale will be off. Manually adjust Scale back to 100%, Reset Basic Motion for each clip or highlight all, right-click> remove attributes> basic motion. Hopefully you don’t have a lot of key framed zoom and pans etc!
  • Rafael Amador
    October 3, 2011 at 12:24 pm
    [Brad Buttner] “I really think it is a simple issue relating to the sequence settings.
    Is there perhaps a way of just vertically stretch the clip, as it seems as though the footage is squashe”
    If your sequence settings are OK and the footage match your sequence settings:
    -Select all the clips in the time-line.
    – Left-click > Remove Attributes > Basic Motion + Distort.
    rafael
  • Brad Buttner
    October 9, 2011 at 11:45 pm
    Thanks a lot, guys!
    Rafael’s response was most helpful in terms of what I needed to happen, but you have all helped to avoid future problems with my work, appreciated!
    Brad
