Activity Forums Apple Final Cut Pro Legacy aspect ratio problem
  • aspect ratio problem
    Posted by Scott Gaskin on May 25, 2010 at 7:13 pm
    I am very new to FCP so I may just being a bit stupid here. I have imported my footage from mini dv camcorder which was filmed wide screen yet the footage has been pinched and distorted, basically looks like the wrong ratio is set. Should FCP automatically re set to correct ratio? If not how do i change it to show the correct aspect ratio it was filmed in?
    thanks
    Scott
    Scott Gaskin replied 16 years, 2 months ago 3 Members · 4 Replies
  • John Fishback
    May 25, 2010 at 7:53 pm
    With your sequence open go to Sequence Menu > Settings and check the Anamorphic 16:9 box. Hopefully, that will fix it.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Richard Cooper
    May 25, 2010 at 8:33 pm
    Scott,
    In the sequence settings, in the general tab, make sure that the Anamorphic 16:9 box is checked.
    This should fix the problem for you.
    Hope this helps
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Richard Cooper
    May 25, 2010 at 8:35 pm
    oops, it helps if I hit the refresh button before posting a reply! What John said.
    Richard Cooper
    Anchorage, Alaska
  • Scott Gaskin
    June 6, 2010 at 2:15 pm
    thanks for the response
    Scott
