Activity Forums Apple Final Cut Pro Aspect Ratio not changing
  • Aspect Ratio not changing
    Posted by Scott Herriott on August 1, 2022 at 11:12 pm
    Hey there…been attempting to change the aspect ratio of a compound clip from 1920 x 1080 to 1080 x 1920 in order to create an Instagram ad.
    Per a few Youtube videos explaining how…I click Modify in the upper right hand corner, choose Custom in the Video dropdown, put in 1080 x 1920 and hit OK annnnd….it stays the same.
    Any advice appreciated.
    Scott
    Doug Metz
    replied 4 years, 1 month ago
    4 Members · 3 Replies
  • Eric Santiago
    August 2, 2022 at 12:11 am
    Have you tried selecting clip(s) and copy > paste into the right aspect ratio Project?
  • John Fishback
    August 2, 2022 at 12:54 am
    When I want to setup a different aspect ratio, I find it’s best to start with a fresh project (CMD+N). I input the aspect I want (and resolution) and everything works as expected.
  • Doug Metz
    August 5, 2022 at 8:28 pm
    You may need to break apart the comp and make a new one if it’s already in use. When you change anything about a Compound Clip, that change occurs in every child instance.
