Activity › Forums › Adobe Premiere Pro › Aspect Ratio Issue from PPro to AE
  • Aspect Ratio Issue from PPro to AE
    Posted by David Intrator on December 22, 2011 at 7:43 pm
    Hello,
    I’m working in Premiere Pro CS 5.5. and AE CS 5.5
    The question here involves a change in the video aspect ratio when sending a clip from
    PPro to AE.
    In my PPro sequence, the clip is 960×720 (P2 footage) with a PAR of 1.333 making the effective
    resolution in both the source and program monitors 1280×720 or 16:9.
    So far so good.
    I want to send the clip to AE in order to add a lower third.
    I’ve been doing this with “Replace with After Effects Composition.”
    AE opens up, but the clip appears with a 4:3 aspect ratio. When I examine the composition settings, everything seems ok: the width and height are 960×720 with the HDV 1080/DVCPRO HD 720 (1.33) pixel aspect ratio, just as it was in PPro.
    But visually I’m looking at 4:3 instead of 16:9.
    I’ve experimented with the composition settings, but to no avail
    What am I missing here?
    Thanks.
    david
    David Intrator replied 14 years, 9 months ago 2 Members · 2 Replies
  • Vince Becquiot
    December 22, 2011 at 7:50 pm
    Hi David,
    You can simply click on the right top side of your AE comp and select View options, and check the aspect ratio correction box.
    This will not however provide a true high quality preview. Instead, I would recommend you change the comp settings in AE to 1280×720 square and all will be right again.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • David Intrator
    December 22, 2011 at 10:42 pm
    Thanks, Vince.
    david
