Activity Forums Apple Final Cut Pro Legacy Aspect Ratio: DV to D1 Anamorphic then to HDCAM
  • Aspect Ratio: DV to D1 Anamorphic then to HDCAM
    Posted by Lili Lab on April 7, 2006 at 10:26 pm
    Hi I have a problem upsampling my anamorphic footage from DV to Blackmagic 10 bit (D1) Basically I’m getting an aspect ratio problem, and it seems to not compensate for the six pixels when going from 480 to 486…Ultimately we are ending up on HDCAM
    When upsampling DV to Blackmagic 10bit anamorphic using the
    Problems upsampling anamorphic DV to Blackmagic 10bit D1 for Digibeta transcode through Teranax to HD
    Taking a DV (720×480 DV NTSC) sequence into a D1 sequence(720×486 CCIR 601 NTSC (40:27) in Final Cut we find that when viewed anamorphically there is distortion. This makes sense as anamorphic from 720×486 will produce a slight shift in aspect ratio in comparison to going anamorphic from 720×480. This problem is exaggerated when we put the Digibeta (D1) through the Teranax for HD output.
    WE find we can adjust the DV nested sequence withinin the D1 sequence before output by scaling up 1% and altering aspect ratio by 1 (in the motion window) but we get a slight blurring. As there is some loss of image quality already when upsampling from SD to HD we would prefer to avoid this.
    Are there settings we’re missing or fixes that can be used to correct for this?
    Girl Geeks at large
    Lili Lab replied 20 years, 1 month ago 2 Members · 2 Replies
  • Bret Williams
    April 8, 2006 at 4:36 am
    I don’t know all the details, but when you drop a DV seq into SD seq, you SHOULD have 6 blank lines in your video signal. Do not scale up the image to fill these lines. Result will be blurry and field mush. In fact, you’ll need to move the image up or down one pixel so that the upper and lower fields still remain on upper and lower fields and aren’t reversed. In other words, 2 blank lines at top, 4 at bottom, or vice versa. Or all six at the top or bottom if you want.
    So that’d be step one.
  • Lili Lab
    April 19, 2006 at 8:35 pm
    We would prefer not to scale up by that one percent because it make the image soft, but, when it’s upconverted in the terenex, these blank lines become exaggerated. Now I could crop it off, but then it wouldn’t follow broadcast standards. Do you think the best thing is use the terenex to scale it up?
    Would you say the best thing to do is to go directly from the DV even though I’ve slapped so many filters on this piece?
    thanks?
    Sorry for all the quirky questions,
    lili
