Activity › Forums › Apple Final Cut Pro Legacy › Aspect Ratio Conversion
  • Aspect Ratio Conversion
    Posted by Johnb on November 19, 2007 at 3:03 am
    I recently shot a live concert and upon reviewing the footage unfortunately discovered that one of the seven cameras was shooting in Full Screen, while the rest were in Letterbox (a gross oversight by my AD).
    Is there a way to convert that Fullscreen footage into Letterbox without compromising the footage? Or do I have to pan and scan and choose where and what to cut?
    Please let me know.
    John
    Johnb replied 18 years, 10 months ago 2 Members · 2 Replies
  • Michael Sacci
    November 19, 2007 at 5:20 am
    Are the other cameras Letterbox (4:3 with black mask) or 16:9.
    To convert full screen to letterbox you can just mask it, raising the image up and down to frame shoot. If you need to convert 4:3 to 16:9 you have a major challenge on your hand. You have to scale the footage up 133% to make the aspect look correctly.
    IF the latter, the best way to do it is to run it through hardware that can to the upres and aspect change. I have done it going from system to system Play the footage out of a system with the kona3 card that makes the conversion to a laptop that captures with the Io. But you lose the top and bottom of your picture.
  • Johnb
    November 19, 2007 at 5:45 am
    The other cameras were 4:3 with black mask on the top and bottom of the frame.
    How would I go about simulating that in FCP6?
