Activity Forums Apple Final Cut Pro Legacy Aspect Ratio Confusion
  • Aspect Ratio Confusion
    Posted by Steve Price on August 11, 2008 at 7:35 pm
    How do I export my timeline to a widescreen movie?
    A rather basic and obvious question I know…but I’m finding it very confusing.
    I digitise my 16:9 rushes, I make my sequence anamorphic, I export using QuickTime Conversion (LAN/Intranet), I tick the box that says ‘preserve aspect ratio’ and what happens? It makes me a Full Height Anamorphic (squashed up) movie.
    So, I try the same thing again, without ticking the ‘preserve aspect ratio’ – and the same thing happens again.
    Either I’m doing something wrong or Apple have overlooked this quite basic and essential requirement. I think it’s the former…
    Thanks for reading…
    Steve.
    Anthony Dalesandro replied 18 years ago 4 Members · 3 Replies
  • Tom Wolsky
    August 11, 2008 at 7:48 pm
    https://www.fcpbook.com/Video8.html
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Michael Sacci
    August 11, 2008 at 8:14 pm
    In the geometry tab change the Frame size drop down menu to Custom 16:9. this will make the conversion to square pixels for you. This should be only done when you are making a movie that will not go back into an editing program.
  • Anthony Dalesandro
    August 12, 2008 at 4:29 pm
    Steve,
    It depends on what your final output is. For burning to a DVD, the squished anamorphic file is correct. In DVD SP when you place the QT file on a track it will probably auto-recognize that the clip is anamorphic and un-squish it, but if not, you select the display preference in the Track:General:Display Mode tab.
    For a playable Quicktime file I use Compressor from FCP and in the settings there you can specify the display aspect ratio under the Geometry tab.
    Anthony Dalesandro
    anthony@anthonydalesandro.com
    https://www.anthonydalesandro.com
