Activity Forums Apple Final Cut Pro Legacy Aspect Ratio Changes on QT Export
  • Aspect Ratio Changes on QT Export
    Posted by Martin Nelson on October 4, 2007 at 12:59 pm
    My sequence appears to be changing aspect ratio on export. Here are the details:
    The other day I finished a fine cut went to
    File>Export>Using QuickTime Conversion
    and chose iPod Setting and got a sweet little 16×9 QT of my 16×9 HD sequence.
    Client screened it, made comments, I duplicated the sequence, made changes and tonight when I did the same process I got a little 3×4 QT of my 16×9 HD sequence. Why isn’t it coming in 16×9? I also made an uncompressed version by going to
    Export>QuickTime Movie
    and choosing
    Apple ProRes 422 (HQ) 1440×1080 24p 48KHz
    This gave me the desired 16×9 sequence. Both the sequence last week that produced the desired 16×9 results and the revised duplicate have the following settings:
    Aspect Ratio: HD (1440×1080) (16:9)
    QuickTime Video Settings, Compressor: HDV 1080p24 .
    The original footage was shot HDV 1080p24.
    I may need to offer more info to help you help me, but I’m not sure what that would be. I’ve successfully produced the QT I need for mastering, but would really like to post my client, per her request, a version she can load on her iPod.
    Martin
    G5 Dual 2 GHz
    Mac OS X (10.4.10)
    Final Cut Pro 6.0
    Martin Nelson replied 18 years, 11 months ago 2 Members · 2 Replies
  • Rafael Amador
    October 5, 2007 at 2:10 am
    Open your movie with QT. Them Com+J to open the Properties. Click in Video Track> Visual Setting. Adjust the Scaled Size and check Preserve aspect Ratio.
    This works with the most of the .mov. I never tryied with I-Pod movies but I guess is the same.
    rafael
  • Martin Nelson
    October 5, 2007 at 3:37 pm
    Rafael,
    That’s a great tip. I had no idea you could do that in QuickTime.
    Martin
