Aspect ratio
Hello.Ostaria of aid it can. Om work After Effects for dvd menus. Use the CS3. But recently did a project in CS4. What happens is that the appearance of the video was wrong, Memso it being exactly the same settings from other projects I did in CS3. 720 x480 DV 4 ntsc:3. But when done in CS4 is com aspect wrong end. com sure I'm not able to see something. If anyone has had this Probelmas please be grateful if you could help me.
ThanksEduardo
