Activity Forums Apple Final Cut Pro Legacy Aspect Ratio
  • Posted by Bob Root on September 4, 2008 at 11:23 pm
    I’m fairly new to FCP and have a question about the aspect ratio settings.
    I am working with 720×480 DV/DVCPRO-NTSC sources and my sequence frame size has been set to NTSC-CCIR 601/DV (720×480).
    My images are getting squished on the vertical and I’m almost certain this has to be a square vs. non-square pixel issue.
    When I turn off “correct for aspect ratio” in the viewer, everything looks just right.
    So… my question is, am I seeing what my final export will look like with the “correct for aspect ratio” turned off. or am I just fooling myself with my solution?
    Thanks so much for any help you can give me.
    Bob
    Walter Biscardi replied 18 years ago 2 Members · 2 Replies
  • Walter Biscardi
    September 5, 2008 at 12:48 am
    [Bob Root] “I am working with 720×480 DV/DVCPRO-NTSC sources and my sequence frame size has been set to NTSC-CCIR 601/DV (720×480). “
    No, those are two difference things.
    DV is one format and I believe it’s square pixels.
    CCIR601 is standard definition 720×486, non-square pixels.
    Are you just set to the DV-NTSC Easy Setup?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Walter Biscardi
    September 5, 2008 at 1:07 am
    Actually I stand corrected, I just looked at the FCP settings and it is DV-CCIR 601.
    Correct for Aspect Ratio is what you want to see. That’s non-square pixels so you want to see the footage in its true resolution, not in square..
    Read my Blog!
