Activity Forums Adobe Premiere Pro Aspect – Premier Pro CS3 problems
  • Aspect – Premier Pro CS3 problems
    Posted by Harvey Goldberg on September 19, 2007 at 6:59 pm
    I am trying to install Aspect V 5 onto a new Vista Laptop system with Premiere CS3. I am capturing 720P/60 via firewire directly into Premiere from a JVC HD250 camera. When I playback the audio lags behind by about a second and sometimes it drops out all together. When I play the clip in Windows Media Player the audio is fine. Also after opening and closing Premiere a couple of times, I get a DEP error which remains until Aspect is uninstalled. I tried running Premiere in XP compatibility mode but that did not solve the problem.
    I also tried using HDLink to capture outside of Premier but that program simply froze when I tried to use it. So I appear to have some conflict with Aspect.
    I am capturing to a Lacie 1TB drive (2 500GB drives in a raid 0) using and e-sata connection through the PCI-Xpress slot.
    The computer has an intel Duo Core processor @ 2.20 GHz…and a NVIDIA GeForce Go 7950 graphics card with 512MB. There are 4GB of ram on board.
    Aanarav Sareen replied 18 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Aanarav Sareen
    September 19, 2007 at 7:29 pm
    [Elrogg] “I am trying to install Aspect V 5 onto a new Vista Laptop system with Premiere CS3.”
    Are you using the latest version of Aspect HD?
    [Elrogg] “I am capturing 720P/60 via firewire directly into Premiere from a JVC HD250 camera.”
    Are you capturing this footage in Premiere Pro or HD Link?
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Harvey Goldberg
    September 19, 2007 at 9:03 pm
    I am using the latest version of Aspect, I just downloaded it several days ago. I captured sucessfully into Premiere, I could not capture into HDLink, the program froze up on me several times. I must have some conflict but there is almost nothing on this computer but Premiere, Aspect and Norton Anti Virus.
  • Tim Kolb
    September 20, 2007 at 12:56 am
    I don’t know what your experience has been with Norton’s…when i had Macs it was all I used…on PC it seemed to cause utter chaos.
    A computer system builder turned me on to Panda Anti Virus (I think they just changed their name to Panda Security…) and I’ve been using it ever since. It just doesn’t seem to bother video applications like Norton’s did. When you can’t run Vegas on a machine, you know something is really screwing with it.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Harvey Goldberg
    September 20, 2007 at 3:51 pm
    I tried removing Norton Antivirus and reinstalling both Premiere and Aspect but the conflict continues. The sound is still off by a second, HDLink does not work, and after a bit I get a DEP error when I try to open Premiere. I am totally baffled. I removed everything there is to remove from the computer and the problem is still there.
    I could get a USB sound card and see if that works just in case the conflict is with the Azalia Sound System on board. Does anyone have any thoughts on that?
  • Tim Kolb
    September 20, 2007 at 3:59 pm
    I’m not familiar with that sound card myself, but I know that sound cards can occasionally cause conflicts.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
  • Harvey Goldberg
    September 20, 2007 at 7:48 pm
    Do you think an external USB sound card would work with Premiere?
  • Mark Weaver
    September 20, 2007 at 8:26 pm
    When you use the HDLink application does it crash?
    I just started using the HDlink program for converting
    P2 files into CineformAVI’s. I’ve noticed that
    HDlink is incredibly unstable. I mean it crashes everytime
    I try to use the quality mode “high”. I can use all the
    other modes including “film scan” no prob.
    I have also noticed that if I don’t have it setup
    correctly ie removing 3:2 for 1080p24 then rescaling
    seems to make it crash. Alas I don’t have my own P2
    card yet so I haven’t been able to test more. Just a
    few clips with a borrowed P2 card.
    Point is, HDlink is buggy and the error checking/crash
    diagnostic leaves some to be desired.
    I would make sure you have HDlink setup just right
    and then try one file at a time.
    Just my 2cents.
    MBW
  • Aanarav Sareen
    September 20, 2007 at 11:37 pm
    [Mark Weaver] “Point is, HDlink is buggy and the error checking/crash
    diagnostic leaves some to be desired.”
    Ditto and especially on Vista. It was significantly better in XP that it is in Vista.
