Activity Forums AJA Video Systems Aspect Issues
  • Aspect Issues
    Posted by Derek Natzke on June 19, 2007 at 4:40 pm
    I am trying to capture 4:3 and 16:9 material for use in the same sequence. Is that possible in FCP5 and with the LH card? I have worked in the firewire world and trying to get adjusted to the BIG DOG world. Please share your workflow, it would greatly help!
    Szumlins replied 19 years, 3 months ago 3 Members · 2 Replies
  • Walter Biscardi
    June 19, 2007 at 6:31 pm
    Is this HD? I simply capture the 4:3 in Pillarbox mode but allow the Kona to upconvert the footage to HD. We edit in a 16:9 standard HD timeline and either fill the space with a graphic or a blurred duplicate of the same 4:3 image.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Szumlins
    June 19, 2007 at 8:39 pm
    [JKLPost.com] “I am trying to capture 4:3 and 16:9 material for use in the same sequence. Is that possible in FCP5 and with the LH card? I have worked in the firewire world and trying to get adjusted to the BIG DOG world. Please share your workflow, it would greatly help!
    A little more info is needed.
    1) Is this anamorphic SD or HD 16:9?
    2) What is desired editing base (525, 720, 1080)?
    -Mike
