Activity Forums Apple Final Cut Pro Legacy Asking to much from my system?
  • Asking to much from my system?
    Posted by Rob Mclain on February 11, 2010 at 4:53 pm
    I keep getting dropped frames and it is getting really frustrating. I am editing in FC 7 on a MAC PRO 2.66 quad core with 6 gigs ram with a internal RAID. I get read/write speeds of 315/325.
    My project is in 1080 29.97 Apple Pro Res HQ. On video track one I have a 20 second clip that has a fxfactory plugin added to it. A little 3D and motion. On video track 2 I have a PSD file with motion added to it as well. When not rendered the sequence will not not play more than two frames before it drops frames. Once rendered I can play for about 5 seconds, then the frames drop. I have tried changing the playback from dynamic to high, and lowered the amount of real time audio tracks from 8 to 4. My RT is set to safe.
    Is there just to much going on in terms of motion, 3D, and what not for my system to handle? Am I missing any other setting?
    Bret Williams replied 16 years, 6 months ago 4 Members · 3 Replies
  • Rafael Amador
    February 11, 2010 at 5:25 pm
    [Rob McLain] “Once rendered I can play for about 5 seconds, then the frames drop”
    Is the render folder in the RAID too?
    [Rob McLain] ” I am editing in FC 7 on “
    There is already FC 7.0.1
    Rafael
    http://www.nagavideo.com
  • Peter Wiggins
    February 11, 2010 at 5:37 pm
    I take it all your render files are set to go to the RAID?
    Have you made the internal RAID out of 3 disks and then have a single a your boot drive?
    Peter
  • Bret Williams
    February 11, 2010 at 5:53 pm
    If you’re rendering to that raid, it should playback just fine. At that point it’s just playing back a video stream.
    There’s no way in heck that it’s going to play back anything more than a frame or two before hiccuping before it’s rendered. And Fx Factory plugin? Like what, volumetrix? Those plugins are the equivalent of a hand made effect with 5-10 layers of blur, glow, color correction, levels, etc. Then you’ve got 3D and a psd file with motion added to it? Yeah, not going to play back.
    But for a better editing experience, always edit with RT set on “unlimited” and turn off warn of dropped frames. You’ll see when it’s dropping frames, but at least you’ll still see it stutter through effects instead of giving up. You’re going to have to render everything anyway in the end.
    i never understood the safe setting for RT.
