Activity › Forums › VEGAS Pro › Asking for tips to deal with audio adjustments (remove background voice + part of main voice)
Posted by Carlos Silva on July 12, 2012 at 9:02 pmHi,
I have two issues related with same audio event.
a) In the background there are people talking and it is undesirable. Is it possible to apply any filter to remove this background voice?
b) In a very exact part of the audio there is a short undesirable sentence of the main voice I would like to remove. I tried to lower the volume through a volume envelope, but it affects the general sound of the audio. So, would it be any workaround to deal with?
Thanks!!!
CarlosMike Kujbida replied 14 years, 1 month ago 5 Members · 6 Replies -
Chris Warren
July 12, 2012 at 10:07 pma)There is not really a way to remove that background audio without affecting the main dialog. Adobe Audition/Soundbooth has a good filter that can reduce steady background hiss/humm/noise and that may reduce it somewhat. If possible the right way to fix this is re-record the audio if possible
b)When I have to edit audio that has some background sounds/ambient noise I usually grab a section of audio where there is no dialog and use that as a background replacement so when the main dialog drops out there is a some background noise still there and it doesn’t sound so odd. Fadeing it in and out helps it seem natural too.
ChrisW
http://www.azprovideo.com -
Roger Bansemer
July 13, 2012 at 1:05 pmChris is right. Replace that portion with another portion of audio that does not have the undesirable part. Another trick I sometimes use is to mask it with another sound effect. For instance if someone says a few words you don’t want distinguished in a room with people eating lunch for instance, you might put in a sound effect of a few dishes clinking on another track.
A cut away shot of something else helps a bit too. So if you want to further mask the sound, you might put a cut away shot in of a the dinner plates with someone picking up a fork and then add the additional sound over that.Roger Bansemer
Carlos Silva
July 13, 2012 at 3:15 pmThanks everybody for valuable tips!!!
About the comment “Adobe Audition/Soundbooth has a good filter that can reduce steady background hiss/humm/noise”, does anyone know if SoundForge provide similar feature?
Eddie Macarthur
July 13, 2012 at 11:31 pmsoundforge can’t. izotope rx2 has spectrum editing. it can do amazing things, but like all tools you would need to spend time learning it (or pay someone like me who runs a commercial audio/video studio) to do it.all the suggestions from the guys above are good. but sometimes you might have a line of dialogue that you must keep, but a noise (e.g. a bump)happned at the same time. rx2 allows you to go in and remove the bump while retaining desired audio. here is a link to a little job i did for someone, removing mobile phone interference from a wedding video soundtrack, using rx2:
https://www.youtube.com/watch?v=bqlc-dHlsnYSystem; intel i72600k 3.4GHZ, 16GB RAM, Win 7 64 bit. Vegas Pro 11 latest build, Neat Video 3.01. EVGA GTX460 SC graphics
Stealth Recording Studio, Glasgow, Scotland UK
http://www.stealthrecordingstudio.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Roger Bansemer
July 14, 2012 at 12:51 amI use Izotope denoiser very often but I can’t seem to get anywhere with the specrtum plugin. Is there a good tutorial on that one.
Roger Bansemer
