Activity Forums Adobe After Effects Ask about AE CS3 vs CS4
  • Ask about AE CS3 vs CS4
    Posted by Abdul Jamal on July 10, 2009 at 9:40 am
    Hello Everyone!!
    Is it rendering in AE CS3 faster than CS4?
    Here’s the problem
    My Spec (Current):
    Dell Precision M6300
    Win XP x64
    Intel T9300 2.5ghz
    Nvidia FX3600M
    Corsair 2x2GB PC6400/800(BOIS detected 667)
    Seagate Momentus 500GB 5400rpm
    rendering this file:
    Duration 175 Frames PAL settings
    Effects: Particular,Echo,Puppet,Sapphire
    AE CS3
    Time rendering:
    04:08 (60% Memory Usage)
    (win 32,QT NONE Compression,2x1GB of RAM,Hitachi 120GB 5400RPM)
    AE CS4
    Time rendering:
    04:56 (Multi Processing=OFF)
    06:11 (Mukti Processing=ON)
    (win 64,QT NONE Compression,2x2GB of RAM,Seagate 500GB 5400RPM)
    Any Comments would be appreciated??
    Regards,
    newbie
    Les Nemeth replied 17 years, 2 months ago 4 Members · 5 Replies
  • Kevin Camp
    July 10, 2009 at 4:56 pm
    [abdul jamal]
    “AE CS4
    Time rendering:
    06:11 (Mukti Processing=ON)”
    you can get slower performance with mp on if you don’t have enough ram to feed the extra cores, this would appear to be evidence of that. 2gb per core was highly recommended even for cs3, but with 64bit windows each core can grab up to 4gb (i believe yours is a dual core, so 8gb max for ae, but you wouldn’t mind having a bit for the os and other apps too).
    another factor that can effect performance is having the disk cache enabled and set to use the same drive as your media/render drive. if you only have a single drive bus (the internal bus), it would be best to disable disk caching.
    there is an update to cs4 (9.0.2) that addresses some render issues and may help with render performance. if you haven’t already updated, you should.
    i’d be curious how cs3 ran on your new machine and, possibly, how cs4 performs on your older system.
    also, you might want to run the task manager while rendering to see exactly what’s going on. if you see that the cpu performance is low, then there is probably a data bottleneck. if the ram isn’t reaching it’s potential, then the data bottleneck is probably at a drive bus. using information like this you can better address settings, or possible upgrades….
    but the performance difference on an older system with cs3 vs. the newer system with cs4 is curious…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Johnsabbath D’urzo
    July 10, 2009 at 7:06 pm
    Hi guys
    Where would the task manager in cs3 on a mac? i’m also testing some rendering issues.
  • Les Nemeth
    July 10, 2009 at 8:41 pm
    Apps:Utilities:Activity Monitor
    July 10, 2009 at 9:47 pm
    I’m running this app and what’s virtual memory, real memory, process id? the after effects logo says (null) beside it, would you know what that is?
  • Les Nemeth
    July 10, 2009 at 10:54 pm
    You can find the answer to all those questions here. (Beats me typing it in.)
    https://en.wikipedia.org
