Activity Forums Adobe Premiere Pro ASIO soundcard necessary ?
  • ASIO soundcard necessary ?
    Posted by Solagratia77 on August 29, 2006 at 3:53 am
    Hello All…..
    Would I see any perfomance or sound quality increase
    by using ASIO soundcards such as M-Audio Audiophile
    or E-mu 0404?
    I don’t do much recording.
    However in some Audio applications,
    as I build a complex timeline,it get a little slow.
    So now I am thinking about getting on of these cards
    for my audio application and was wondering
    if Premiere Pro would take advantage of them.
    I am currently using on-board Realtek AC 97.
    on Dual Opteron 275s
    I would very much appreciate any sugesstions
    Thank you
    Solagratia77 replied 20 years ago 2 Members · 2 Replies
  • Blast1
    August 29, 2006 at 8:22 pm
    Premiere doesn’t use the sound card per’se to process audio except as a I/O device, the sound card doesn’t add or detract from audio imported with DV and digital audio files like WAV, MP3 etc that are used in premiere, I find on-board sound is fine for monitoring Premiere sound with some decent speakers, to do more quality work with sound itself, importing or exporting analog audio I like to use external devices that A/D convert the audio outside of the computer.
    Check the drivers that came with the MoBo there maybe ASIO drivers included, if not generic ASIO drivers are available on the net.
  • Solagratia77
    August 29, 2006 at 8:49 pm
    Blast1
    Thank you for clearing things up.
    Thank You.
