Activity Forums AJA Video Systems ASA jes wundrin
  • ASA jes wundrin
    Posted by Norman Frizzle on March 21, 2006 at 1:07 am
    Just received new Xena HS board. I find inside the board itself and a set of breakout cables. On neither do I see Firewire import for DV. My dealer will be installing it in a new custom PC so I can’t access info on also-included CD.
    How do I capture DV?
    Tim Kolb replied 20 years, 5 months ago 3 Members · 2 Replies
  • Andrew Kramer
    March 23, 2006 at 12:36 pm
    Capture DV using a Firewire card. To capture using the card from a dvd you may need a converter to take your video signal and audio into the sdi input. Remember your source is already compressed. aja tech should know what converter you need.
  • Tim Kolb
    April 12, 2006 at 1:13 am
    I’ve had very good luck with the Convergent Design SD Connect for DV/analog into SDI…
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
