Activity › Forums › Adobe After Effects › artistic photoshop-like effects in AE7
Posted by Stef Prein on November 20, 2007 at 4:22 pmIs there a way to get the same effect in AE7 or AE CS3 as the Photoshop artistic filters? I read this topic: Do Photoshop Filters Work in AE7?, but that isn’t really what I am looking for. It’s a good alternative. But aren’t there any possibilities in AE?
Thanks in advance!Ollie Wainwright replied 18 years, 10 months ago 4 Members · 5 Replies -
Kevin Camp
November 20, 2007 at 5:07 pmnot quite the same one effect solution with the ae bundled effects, but you can try the median effect to get a kind of paint-like look (kind of similar to palette knife).
you could then use textures as displacement maps for the displacement map effect or even as overlays using blending modes to add texture.
aharon’s cartoonification tutorial might offer some other methods…
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Ollie Wainwright
November 20, 2007 at 5:45 pmdo you know of any other cartoonification tutorials that give a better effect???
Kevin Camp
November 20, 2007 at 6:00 pmactually that’s the only tutorial i’ve seen doing anything like trying to create a cartoon like animation from video…
you may be able to somewhat better results with aharon’s process by planning on layering some of the treatments… to smooth the color out, you may want to try blurring, wide time and/or extreme chroma smoothing (like remove dv blockiness but with more channel blur). then use a different render for the black outline with settings to try and better isolate the edges. then composite the two. it also may work better with keyed footage, where the subject can be treated differently than the background.
Kevin Camp
Mike Zimbard
November 20, 2007 at 6:24 pmDigital anarchy makes a separate plug-in called Toon-It that’s designed to turn video into Illustration. I’ve had varying levels of success with it depending on the source footage. It takes a decent amount of manipulation to get something looking right and you may want to try out a demo (digitalanarchy.com) to see if it will do what you’re looking for. Good luck.
– Mike
Ollie Wainwright
November 22, 2007 at 11:51 pmthe only problem is that i can’t afford it and i cnt find a crack for the demo =( i’m just a poor student who needs to have a quick fix because my final major project adopts this technique a lot.
