Activity › Forums › Canon DSLR Cameras › Artificating when converting 5D to ProRes 4444
  • Artificating when converting 5D to ProRes 4444
    Posted by Danielle White on December 13, 2012 at 7:30 pm
    I have been using mpeg streamclip to convert 5D footage to Apple ProRes 4444 to be used in Final cut. I have interlacing turned off. I am selecting unscaled as the frame size. I have also tried several different codecs. Every time I convert, I am seeing artifacting in my reds. Has anyone else had this problem? Any ideas for fixes?
    Sareesh Sudhakaran replied 13 years, 9 months ago 2 Members · 1 Reply
  • Sareesh Sudhakaran
    December 14, 2012 at 9:22 am
    Export an uncompressed TIFF frame from your NLE, at the point where you think the effect is worst. Assuming you haven’t blown the red channel during acquisition, it could be a quirk in the converter.
    Or, it could be a monitor problem. Have you checked it on another monitor?
    https://www.wolfcrow.com – Workflow information and support for filmmakers, photographers, audiographers and videographers.
