Activity Forums Adobe InDesign Artifacts when placing an illustrator file into InDesign
  • Kelly Johnson
    April 22, 2006 at 11:20 pm
    Usually won’t translate. Try expanding everything first.
  • Mike Behrens
    April 23, 2006 at 12:05 am
    Thanks thumbslinger, i’m sorry i am a noobie to InDesign, so I don’t quite understand. . . .
    Perhaps I should have uploaded the InDesign File?
    Here is the link:
    https://mikebehrens.com/forums/place-problem.indd
    -Mike Behrens-
  • Kelly Johnson
    April 23, 2006 at 1:38 am
    No worries…I meant in Illustrator to use Expand feature. But, I opened your files and saw what you meant.
    I saw the marks in Illustrator as well as InDesignCS. I raterized the Illustrator file and the lines dissappeared.
    Unless you have to have a vector file, I’d just rasterize the Illustrator file for placement in Illustrator and save the vector for any edits.
    However, if you need to have vector placed, I’d just make gradients to emulate the extrusion. It will be a less complicated eps file and InDesign shouldn’t choke on the interpretation.
