Activity Forums Adobe After Effects Artifacts using frame blend on DPX
  • Artifacts using frame blend on DPX
    Posted by Scott Robert on July 15, 2010 at 1:15 am
    CS5 & 4 – same issue.
    I’m working 4k DPX files from R3D in 23.976.
    I have a quick shot that is sped up by only two frames. Don’t ask me why – it’s a director call.
    So in the shot we lose 2 frames and you can see the 2 jumps in motion.
    I turn on the Frame Mix in frame blend which creates ghosting. We don’t want that.
    I turn on the Pixel motion and that solves it, BUT there are artifacts creating harsh lines and blocky edges.
    Why am I getting this? What can I do? Thanks.
    Scott Robert replied 16 years, 1 month ago 2 Members · 5 Replies
  • Scott Robert
    July 15, 2010 at 7:21 am
    I just discovered the new Timewarp plugin in AE. Seems to be working…..
  • Tudor “ted” jelescu
    July 15, 2010 at 12:53 pm
    That or you can try time remapping…
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Scott Robert
    July 15, 2010 at 4:45 pm
    Opps, I failed to mention that. I used Time Remapping and then the pixel motion which created wavily artifacts.
    July 15, 2010 at 5:20 pm
    Try using time remap with no Frame Mix or Pixel Motion turned on.
    Also, instead of using the in and out keyframes of the time remap, set keyframes one frame in and one frame before the last frame, then move the last two keyframes to get the desired length- don’t ask me why, but sometimes that helped getting rid of the funky artifacts.
    Just curious- have you used a plain old time stretch?
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
  • Scott Robert
    July 15, 2010 at 5:34 pm
    I have not used the time-stretch. I didn’t know what percent to speed it up to. I just knew that the whole shot needed to be two frames faster. I’ll mess with it and see what happens.
