Activity › Forums › Adobe Premiere Pro › Artifacts during capture PP 2.0 8800GTS 640
Posted by Rainless on August 13, 2007 at 5:32 pmI was able to capture just fine with my old video card (7600GS), but ever since I installed my 8800GTS I’ve been getting artifacts during capture in Premiere Pro 2.0… but ONLY in Premiere Pro 2.0
If I go into Windows Movie Maker or any other program… the artifacts aren’t there. During playback… the artifacts aren’t there. It’s ONLY during capture.
So what gives?
Thanks in advance.
Rainless replied 19 years ago 3 Members · 12 Replies -
Blast1
August 13, 2007 at 7:38 pmAre you seeing the artifacts while you are capturing? or after in the data? if only while capturing try updating the video card drivers.
Roger Averdahl
August 13, 2007 at 7:59 pmNo real answer, but i have the same problems during capture with a EN8800GTX on PPro 2.0 and PPro CS3.
I have tried the latest drivers to no avail.
Blast1
August 14, 2007 at 3:11 amIf you have problems with a original installation, and have tried updated drivers, try rolling back the drivers to a version less than the original installation.
Rainless
August 14, 2007 at 8:05 amYeah I don’t think that’s going to work. The earlier G80 drivers are notoriously unstable. 🙂
@ Averdahl – Which drivers and which operating system are you currently using?
I’m using Forceware 158.27 beta in XP. I believe the latest official drivers are 158.22.
And, yes, the problem is only during capture. I suspected it had to be a G80 issue since I never had the problem with all my other video cards.
Blast1
August 14, 2007 at 1:09 pmHere’s something else that maybe causing the problem, your 7600 was DirectX 9, your new card is DirectX 10, Ppro2 was made before DirectX 10 came out.
Rainless
August 14, 2007 at 4:03 pmDirectX 10 is only an API. It’s software… and it does not exist in Windows XP. So whether a video card is DX10 or DX9 compatible or not is irrelevent: In Windows XP it would only use DX9.
Just tried updating my drivers. (Ran drivercleaner, got rid of ALL the NVIDIA drivers, installed new drivers.) No such luck. I’m 100,000 percent sure this is a Premiere issue (since it captures fine in Movie Maker and every other capture program) and not a video card issue.
Roger Averdahl
August 14, 2007 at 6:55 pmI use Win XP Pro x64 and the drivers for the graphic card is 158.22.
I have the very same problem on Win XP Pro with the same drivers, 158.22.
The latest drivers are 162.18, but i have not installed them yet.
/Roger
Blast1
August 14, 2007 at 7:42 pm[rainless] “I’m 100,000 percent sure this is a Premiere issue”
Premiere uses DirectX
Blast1
August 15, 2007 at 6:59 pm[rainless] “but it uses DirectX9 when you’re in XP…”
Gee when don’t you use XP? let me quess you have a Mac with boot camp?
