Activity › Forums › Adobe After Effects › Artifacts – Alpha Chanels – Particle Illusion
  • Artifacts – Alpha Chanels – Particle Illusion
    Posted by Chris Ricci on July 19, 2012 at 1:27 am
    help!!!! I am trying to import footage with an alpha channel from Particle Illusion to AE and when I output I get artifacts
    I tried importing as AVI, PNG, PSD same thing.
    I tried interpreting footage, same thing…
    Any help would be most welcome!
    Chris Ricci replied 14 years, 2 months ago 43,409 Members · 1 Reply
  • Chris Ricci
    July 19, 2012 at 3:26 pm
    Sorry for the lack of information!
    I am using the latest version of AE.
    I am using Particle Illusion and I create an effect and export it out with an alpha channel. I have used PNG, TIFF and AVI progressive
    Then I import it into AE with a comp that should match the size, frame rate, progressive etc..
    When I export it out as AVI, MP4, MOV I get wavy lines that show up at the bottom of the screen.
    If I do not use that particular effect, it seems to be ok. I will try to show a post later.
    Thank you.
