Activity › Forums › AJA Video Systems › artifacting with color correction
  • artifacting with color correction
    Posted by Peter on July 15, 2005 at 7:17 am
    10.4.2 and fcp5.2 with the 1.1.2 kona driver I am woking on some 10 bit pal digibeta footage and done a color pass on it I am noticing as I am shifting the color I an getting red dots (small lines) that come and go as I ajust the color. The problem is some of them are rendering. Has anyone else had this happen?? Is it final cut or the Kona driver?
    Peter replied 21 years, 2 months ago 2 Members · 2 Replies
  • David Battistella
    July 15, 2005 at 6:02 pm
    This is a codec issue. Which sodec are you using. Are you using Apple’s 10-bit uncompressed codec?
    Can you try another codec to replicate the problem.
    David
  • Peter
    July 16, 2005 at 3:25 am
    yes the sdi 10 bit kona2 setting I will give it a shot
