Activity Forums Apple Final Cut Pro Legacy Artifacting in text of MPEG4 exports from Compressor
  • Artifacting in text of MPEG4 exports from Compressor
    Posted by Thad Macnamara on May 15, 2012 at 8:17 pm
    I am experiencing a pulsating artifact in Compressor MPEG4 exports of self-contained movies. The artifacting is especially noticable in stills with text – the more text the worse the pulsating.
    It looks like ringing, but is not constant. It tends to muddy up the background picture near the text. I am exporting SD from FCP 6.0.6. What am I missing in the workflow that causes this?
    Thad Macnamara
    Chris Tompkins replied 14 years, 4 months ago 2 Members · 1 Reply
  • Chris Tompkins
    May 17, 2012 at 11:13 am
    That’s compression.
    You Can:
    Compress at a higher bit rate.
    Start with a higher res image/video.
    Use thicker less texts.
    You can also try:
    Change the compressor settings in the FCP sequence to Prores 422 or 8 bit uncompressed and re-render fully before exporting to compressor.
    Chris Tompkins
    Video Atlanta LLC
