Activity › Forums › Apple Final Cut Pro Legacy › Artifacting around FCP Text with Drop Shadow
  • Artifacting around FCP Text with Drop Shadow
    Posted by Shaon Reed on September 20, 2006 at 4:38 pm
    Having a problem with the built in Text on FCP 5.1. The text looks fine when unrendered but when we render it out there are green atifacts around the outside of the Text. Kind of like a poorly keyed graphic. The only thing we can find is that this only happens when we are using the drop shadow inside the motion tab. We noticed this occasionally in FCP 4.5 where this project was created and it was fine there. We upgraded and to 5.1 and the artifacting began. Anyone run across this? Thanks!
    Shaon Reed replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
